Belt tensioner torx bit
turbotim2
Post by turbotim2 »
04 XC70
Can someone tell what size the torx bit is for the tensioner on the drive belt? I have borrowed the bit in the past and remember it being a T75 but I want to be sure before I buy one. Thanks!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Search forum, but I think it is T60.
I wrote the tricks in the XC90 forum.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
If you have the 14mm bolt in the center (there may be a cover over it), you can grab it by this bolt @ 19:20 in this video
turbotim2
Post by turbotim2 »
I did search and nothing came up.
2004 XC70
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
turbotim2 wrote: 21 Mar 2018, 05:53 04 XC70
T60 or 14mm is correct.
The fcp tool makes it easier to get in there.
https://www.fcpeuro.com/products/volvo- ... -8760#desc
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
14 mm is correct and so much easier than a torx head bit or socket.
Consider a ratcheting 14 mm box wrench with a pipe over it to make the lever long. Then the job is simple and you have a nice wrench you can use in dozens of other places.
Post by cn90 »
I wrote the detailed DIY timing belt, water pump etc. for 2005 XC90.
All the tricks are there.
DIY: 2005 Volvo XC90 2.5T Timing Belt, Water Pump, Serpentine Belt
viewtopic.php?f=10&t=83521
turbotim2
Post by turbotim2 »
Thanks, I have done a bunch of timing belts on these just couldn't remember that torx.
2004 XC70
Has thanked: 1610 times
Been thanked: 4068 times
I believe the transition from Torx to 14mm hex head was in the ba$tards 1999.
turbotim2
Post by turbotim2 »
My 04 is definitely torx not hex.
2004 XC70
