01 V70 Ball Joint Help
davidfcole
Year and Model: XC90 2005
Post by davidfcole »
MUCH EASIER way. Simply get a stout chisel on the lip of the ball joint. A few leisurely but persistent taps with a 2 or 4 lb sledge works the edge of the chisel in prying out the pressed-in ball point a mm or two, then repeat a bit more onto opposite side a bit wider and so on. I was able to get both 10 year old ball joints (2005 XC90, but same anatomy) out in 10 minutes with everything still mounted onto car, no problem. Cleaned out the hole with a wire brush on a cordless drill, blew it out with compressed air (or brake cleaner or whatever you have). Super easy to tap the new ones in with a light hammer. Tightening down the mounting bolts finished it off with no gaps. Never even detached the ball joints form the control arms.
Dave
2005 XC90
2006 S80
previously had a S70, 850, and a 144 in college
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
How is it possible to replace ball joints without detaching them from control arms?
