OK update...... While working on the PCV and the ABS controller, I removed and serviced the PNP switch. I had to re-shape one of the contacts as it was quite a bit off square.
No change in symptoms yet, still a delayed and or VERY harsh 1-2 shift when cold (much more delayed than the normal delay when cold). Runs like a champ when warmed up.
Now to be completely fair, I think the fluid level might be a bit high since I did the flush so I will get that corrected before I go any further.
Transmission Code "Unknown DTC29"
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
boosted5cyl
Interesting info here, not the extact same transmission but interesting that the solenoids include the manifold/valve: http://www.sonnax.com/publications/tran ... -solenoids
boosted5cyl
no updates yet but im eyeing up the el cheapo set of three solenoids I see on ebay.
boosted5cyl
OK just pulled the trigger on these:
http://www.ebay.co.uk/itm/TRANS-SOLENOI ... 0527044018
S1 & S2 as wel as TC Lockup solenoid for $129. Might as well do all three while I have the cover off.
boosted5cyl
Hmm. Well I guess the car knows I bought the solenoids, its magically started to behave "better" this week. Not perfect but better when cold.
I did a drain and fill a couple of weeks ago and the fluid was a bit dirty, what's interesting is that I did a fluid exchange a couple of months ago but I honestly can't remember if I drained from the plug or not when I did the exchange. Assuming I didnt pull the drain plug when I did the exchange (would be a silly mistake but possible) maybe there was some sediment in the fluid that didn't get taken out when I did it and it was clogging things up... Will do another drain and fill during the week and see how things look. I still have plenty of fresh fluid left from the 5.5gal drum I bought!
- 1170 Views
- 441 Views
Last post by FLXC90
- 1181 Views
Last post by Billsfan
- 1113 Views
Last post by RigsPGT
- 1331 Views
Last post by Grooveman221
