The last word on oil change intervals?
Has thanked: 1610 times
Been thanked: 4065 times
My use case has changed so much I just do one annual oil change on every car in the fleet
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
cn90 wrote: 16 Sep 2024, 14:00 Brining back an ancient thread. What interval is everyone doing now?
Me: P2 cars with 2.5T engines > 100K miles. These cars need 1 qt of oil added every 1,000 miles or so...
- Synthetic 5W40
- Mahle oil filter
- Every 7K miles or so...
So you routinely add 5-6 quarts between 7k oil changes? That sounds way out of range, the cars must have leaks?
Otherwise I'm doing exactly what you said, except that my P2 cars need a quart about every 3500 miles. I.e. top up one quart halfway through the OCI, then by the time it needs another quart it's time to change the oil. Works out well.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
erikv11 wrote: 16 Sep 2024, 16:41 So you routinely add 5-6 quarts between 7k oil changes? That sounds way out of range, the cars must have leaks?
I agree, at this rate the oil is always fresh, and you're just changing the filter.
Sounds like it has seal issues. Actually, sounds like it's leaking like a sieve.
5 others that came and went
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
We have two Volvos, 2001 C70 T5 and 2002 S80 T6, each with 150K plus miles, that we now drive only during Summers, less than 2K miles a year. I change the oil and filters once every two years, synthetic, store brand. They don't consume a drop of oil, engines are very strong and fuel consumption is very low. Oil still looks new after the two years.
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Change intervals in my opinion varies by driving habits and oil quality. A vehicle run on short trips can create crankcase moisture and ultimately sludge if temperatures don’t get hot enough to burn that moisture off. Conventionals and Semi synthetics are also more prone to sludge. I personally would not trust the oil or filter any quick change shop uses.
I bought my kids 02 S60 with 150k miles and found significant sludge evidence, pretty sure it had 7500 intervals. With a few 2000 mile then 3000 mile intervals the engine has cleaned up, added a 1/2 qt of marvel mystery oil on the first few changes to help gently break the sludge down without clogging the pickup screen.
Similar with the 05 XC90 I bought at 190k miles, 7500 intervals and sludge evidence. Looked black like diesel oil in 3000 so changed it.
So, I go a lot off of oil color. If black at 3000 I’ll change it, if the vehicle had some long trips I may stretch to 5000. I don’t want sludge so never longer than 5000 for me–a quality oil and filter is $30-40 or less at Walmart.
08 C702.5T (sold)
The non-Swedes:
