Oil leak dripping
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Shouldn't he have a quick look at the PCV system too? Won't that blow these seals?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
rmmagow wrote:Shouldn't he have a quick look at the PCV system too? Won't that blow these seals?
Great advice; cam seals usually don't blow out without a reason!
Have a look for the early symptoms:
https://www.matthewsvolvosite.com/forums ... =1&t=28487
'98 S70 T5
2016 Chevy Cruze Premier
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Eeeehhhh! The cam seals wont blow again any time soon. The RMS will go long before the cams seals do again.
jblackburn
rspi wrote:Eeeehhhh! The cam seals wont blow again any time soon. The RMS will go long before the cams seals do again.
The cam seals are the weakest points. I blew 2 (same one) in a relatively short time frame. Then the timing belt side ones go. Those are a pain...
'98 S70 T5
panda30
Year and Model: 98 s70 glt
Post by panda30 »
Thanks to everyone with the oil leak help,I whats the easiest test to see if I have a plugged pcv,I only have a little smoke from the Dipstick,no smell inside car and no smoke from tailpipe and should I continue using synthetic oil and do the Seafoam cleaning like they recommend,car has 170K.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Take your oil cap off and just sit it on top and start your engine- does it suck in or float up? This is a good test. My experience is that if the PCV is clogged, no amount of synthetic oil use or seafoam is going to clear it out- it's usually the hows that connects from the bottom of the intake (accordion) hose.... Certainly try the seafoam first though.
panda30
Post by panda30 »
So with the oil cap test if it floats the the pcv might be clogged I hear someone say put a ballon on the dipstick tube and see if it inflates it,Now if it inflates it should it inflate quickly or just a little will it mean also that it's clogged or getting there soon.
