yes, the wobble is the main indicator of a bad wheel hub assembly, they should be tight, no wobble.m491 wrote:I need to get the car up to check the hub assembly. What is the signs of a bad assembly? Just shaking of the wheel or anything else I should be looking for?
New front suspension noise
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
oldschoolvolvo
- Year and Model: 1979 242DL
- Has thanked: 1 time
Are you having trouble tightening the wheel? Are they cross-threaded? This seems unnecessary.xHeart wrote:I plan on replacing all 20 wheel lugs at next brake rotor and pad replacement, likely this Fall.
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
I have the final fix. It was the end link bolts not torqued down fully. Retorqued the bolts and the sound is gone. It's the dumb things some times.
2019 XC60
1997 854 GLT (sold)
1996 855 Platinum (sold)
1994 854 GLT 5 speed (sold)
1995 854 (RIP saved my kid)
2005 V70R (sadly missed)
1998 V70 AWD (sold)
1997 854 GLT (sold)
1998 V70 AWD (sold)
- Has thanked: 311 times
- Been thanked: 817 times
It's a very common problem on these cars, you aren't the first to run into it and you won't be the last ... thanks for posting up the solution.
reg gole
- Year and Model: 1998 S70 T5 SE
Interesting. I posted similar symptoms in the suspension thread. I'll check on my endlinks too. I replaced them both BEFORE all the major strut replacement was done and never have my symptoms. Only after I removed and replaced all the other parts did a test drive reveal the sound. Thanks all.
- 15 Replies
- 3415 Views
Last post by dosbricks
- 976 Views
Last post by Willber
- 13 Replies
- 5691 Views
Last post by arrrxivvv
- 12 Replies
- 3345 Views
Last post by RickHaleParker
- 20 Replies
- 5230 Views
Last post by clifford06
