Okay, I'm confused now....... Is the axle stuck in the transmission, or stuck in the hub?
... Re-reading the original post, it appears that he's trying to free it from the knuckle, in which case I think the puller is still a valid approach.
Also, I notice that nobody has suggested letting it soak in penetrating oil, something else I tried before resorting to the 3 prong pulller. I bet that's already been tried....
Paul
Can't get axle out of bearing hub -tried EVERYTHING!
- Been thanked: 504 times
Trust me, I have done it:
1. Soak in PB Blaster, WD-40 etc.
2. Then heat with propane torch, a little smoke will come out.
3. Use the 3-leg gear puller.
It will come out.
It will come out.
- Has thanked: 1613 times
- Been thanked: 4077 times
...and PB Blaster starting 3 days before work, to let it work its magic!!
- ThatBitch_MacGuyver
- Year and Model: 850 1997 wagon
I've soaked the heck out of the HUB in PBS blaster and nothing seems to work. Is their a circlip I missed that retains the axle into the hub/ wheel bearing? I will have pictures later I promise . I'm not trying to yank the cv from the transmission just the hub. To clarify, the hub is the knuckle with the wheel bearing attached to it. That is what I am trying to separate. The axle from the hub.
MrPc
- Year and Model: 850R 1996
- Been thanked: 2 times
There's no circlip. Just corrosion/friction.
xHeart already touched on this, but it's still not clear: Have you got the steering knuckle detached from either the lower control arm or the strut? If it's not, I don't think there's enough slop in the cv's to push the shaft out. But I expect there would be plenty enough to at least break it free. But when I did mine, it didn't pop free the way things normally do with a puller. It slow pressed out, resisting all the way...
I would try heating next. Maybe a few taps on the puller when it's all bound up? Oil the puller threads and bearing surface well...
Paul
Paul
Red Red '96 855R, 169k
...and PB blaster needs time to work. Like days. Keep hitting it and letting it work in.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Below is a photo from my project.cn90 wrote:Trust me, I have done it:
It will come out.
In addition, Ozark Lee and cn90 refer to ride-height in their notes, where the axle/CV is most at ease.
It may cooperate.
- Has thanked: 312 times
- Been thanked: 818 times
This.MrPc wrote:There's no circlip. Just corrosion/friction.
Paul
- Don't do anything until you separate the control arm from the knuckle
- Somewhere in this thread people got confused and started posting about the axle in the trans (circlip); there is no circlip at the hub.
- I would definitely not yank apart the CV.
- Lots of PBblaster
- A little heat
- You are almost surely dealing here with metal adhesive from the factory, or from a replacement. It will ease apart not pop, so use the puller.
- Use a mix of tapping on the axle nut (know that you will ruin the nut but PROTECT the axle threads - I have an axle nut I use specifically for un-sticking stuck axles) and, the 3-prong puller
Nothing new, all these bits were already posted, but FWIW it's what I would do.
I will try a little torch work next but from using the 3 prong puller it seems it should have released it a little. I know the boards have all the answers I could do a little more digging to find the answer but I have to say that direct answering is the best. I thank all of you for your kind insight and encouragement I don't think I could have found more in depth answers than I have right now. Thank you. It's off to the races now I gotta pull everything apart again and try to use the torch without igniting my car on fire.
BTW. I'm working out doors on a pea stone and gravel driveway with a piece of 4'x4' plywood as my work surface. My suggestion is to use an Easy-up tent next time or the "tramp stamp" area on your butt will get a nice red smile on it.....like mine, or use plenty of sunscreen. This year especially because of the solar flare. Just thought I'd throw those conditions in there. Heh heh heh.
-Woody
-Woody
- 16 Replies
- 3624 Views
Last post by MadeInJapan
- 18 Replies
- 5144 Views
Last post by difflock54
- 1038 Views
Last post by rice240
- 2489 Views
Last post by [email protected]
- 1909 Views
Last post by Mikaro07
