Front Driveshaft Removal V70 XC Topic is solved
This topic is in the MVS Volvo Repair Database » Front Driveshaft Removal V70 XC
rcundy1
Year and Model: 2002 S60
Post by rcundy1 »
The oil you see is actually grease that has come out of your CV joint due to a broken boot. If not repaired the CV joint will fail and the above repair will be required.
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
RCUNDY1 thanks much for the reply,
Once again, 2001 model shall not let me down; the vehicle has been shaking quite a bit while accelerating (especially uphill and I do have a circular spray around the inside of the wheel well) my next project will be to replace driver's side axle assembly...once the part comes in and I find the courage to start taking my car apart pictures shall follow (as usual). Any suggestions, additional parts needed and most important is an alignment necessary?
BTW, the driveshaft assembly from FCPGROTON any good.
http://www.fcpgroton.com/product-exec/p ... ory_id/103
Thanks much...
Jan
Former 2001 V70 2.4T owner
jmoss
Year and Model: V70 2001
Post by jmoss »
I think I have this problem but I am not sure. I am hearing a loud crunching sound from the front passenger wheel whenever I go over a bump of any size. If I put my foot on the top of the tire while the car is sitting on the ground and push will I feel some play in the wheel like I imagine a wheel with bad bearings would feel.
Even if I don't have this issue, I wanted to commend you for the great pics and explanation. It is great to see that people still care about sharing information and trying to help each other.
Mike850
Year and Model: 1994 850, 1997 850
Post by Mike850 »
jmoss wrote: I am hearing a loud crunching sound from the front passenger wheel whenever I go over a bump of any size. If I put my foot on the top of the tire while the car is sitting on the ground and push will I feel some play in the wheel like I imagine a wheel with bad bearings would feel.
jmoss,
It could be that your "wheel bearing" (referred to as a wheel hub assembly) could be bad. After I purchased my 850 a couple years ago, I was experiencing what you describe. Below is a picture of my car's wheel hub assembly after removing the spindle to inspect it. It was completley destroyed! The bearing race had disinegrated and all the ball bearing were loose in the hub. I replaced both hub assemblies and purchased them from FCP Groton for seems like around $100 each.
Good luck in diagnosing the problem!
1994 Volvo 850 GLT
1997 Volvo 850 GLT
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
There is no thing as a front driveshaft.
If you mean a drive AXLE, (right and left front) a couple of hundred bucks and an hour+ or so of labor
If it's the PROPSHAFT (or driveshaft to some of us but not FRONT), then yes, they are $1000
Rebuilt from Colorado Driveshaft $450 or so
toddmax
Year and Model: XC90 03
Post by toddmax »
Anyone know if this would be close or related to the XC90 instructions?
03 XC90 T6 leaking transmission fluid from the axle, and looks like I need to do a replacement.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
More different than similar. You have a A341E (30-40LE) transmission, which was used in XC90 and RWD Volvos.
Concepts similar; specifics different. Post in the XC90 forum and you may see a more detailed response.
Also -> Amazon link
RobTaylor
Post by RobTaylor »
One thing that really helped me out is that I removed the bolts attaching the upper control arm to the strut assembly. This allowed a lot more movement and gave me tons of room to get the axle in and out. I was able to remove and replace both axles in about two hours using basic tools.
Thanks for the great pics, and the original post is excellent! I would have really struggled without it.
007
Year and Model: XC90 0406, 2012 C70
Post by 007 »
matthew1 wrote:Holy smokes, those are good!
Sorry bout the delay; I'm lazy and benefit from these public proddings.
Hello Matt, I need to purchase both sides axles, so I would like to know if DSS brand is a good option?, the OEM axles are very expensive and I don´t want to waste money on OEM if DSS are working well as OEM.
I will appreciate your reply. Rgds.
tulliallan144
Year and Model: XC70 D5 2005
Post by tulliallan144 »
Excellent Pics
Used them to replace the reluctor ring on the CV end of the shaft, Didnt need to to take the shaft fully out and fitted the ring whilst the shaft was still on car. Had to use the jack under the ball joint to get the correct angle, a bit of wiggling and out the shaft popped.
Thanks
Volvo XC70 D5 2005
