OBD I style LED Flash code Reader.
This topic is in the MVS Volvo Repair Database » OBD-I LED Code Reader & DIY Instructions
Ben850
Been thanked: 7 times
Post by Ben850 »
scot850 wrote:What a marvelous piece of kit! When does it go into production? Is production limited by deodorant use?
Sometimes you guys on this website aren't just great, but amazing!
That was a nice compliment Neil.
I was pasting this link to a new friend from Sweden.
Thanks for the Kind words.
Paul.
Edit:
Pm, me for production availability.
I have been a bit funky,(odiferous) in my work lately.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
dbooth914
Year and Model: 1996 850
Post by dbooth914 »
Using pin 3, I get nothing back from my new homemade tool, no flashes after the momentary contact, although I do have a CEL.
Using pin 6, the tool does seem to work, flashing out an error 325 from the ECC. So I know the tool is wired correctly.
Any ideas? The car is a 1996 Volvo 850 wagon, no turbo.
Thx!!
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
dbooth914,
Since you have 1996 850 no turbo, I'd guess you do not have Motronic 4.3, but instead have a Motronic 4.4.
The flashing tool on pin 3 is for use with Motronic 4.3 (and maybe for some other non-Motronic 4.4 ECMs).
A USA-destined Motronic 4.4 can have its codes (that cause the CEL light) read in two basic ways:
1. via standard OBDII emission diagnostics (like would be used by a standard, cheap, run-of-the-mill OBDII scanner, ELM327 device, etc), or
2. via the KWPD3B0 protocol that the '96-'97 850 COMBI, SRS, ABS, AW 50-42, Power Seats, Motronic 4.4, etc use (and which Vol-FCR uses, volvo850diag can use, ELM327 device can use if it has first been setup properly for KWPD3B0 access, etc).
Solution 1 is adequate to debug most Motronic 4.4 caused CEL situations.
Solution 2 can sometimes provide a little better view of specifically what is happening, since the Motronic 4.4 (acting as ECU 7A) might report multiple, distinct DTCs, when the OBDII emission diagnostics based Solution 1 might only report a single DTC (or two DTCs which are identical).
Unless you hear otherwise from some Motronic 4.4 owner, you should assume the flashing LED tool is not for use with a Motronic 4.4. I personally would advise against using a flashing LED tool on pin 7 of any of the ECUs that Vol-FCR handles. I think you would be asking for trouble.
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
dbooth914
Post by dbooth914 »
Thanks for the quick reply. I guess I misunderstood which Motronic I had.
I have the ELM327 BT and can use it to get the basic engine DTCs (current CEL is a P0455 which I'm working on).
What I was hoping was to get some info back from the electronic climate control ecu, as my ac just quit yesterday. When the pin 3 connection did not work, I figured the 3-2-5 from pin 6 may have been a red herring?
I have the volvo850.diag working with the BT ELM327 device, but I cannot understand the output, even with the help of the interpreter. It also looks like that tool does not read from the ECC ecu? I need to spend more time learning the tool, as it looks like a great resource.
T64me
Year and Model: 04V70R/05S60R/07S60R
Has thanked: 6 times
Post by T64me »
Electrical stuff has always been my weak point. Is this really as simple as it appears? If I am reading the diagram correctly, I could take a simple test light and connect it between connections 3 and 16. Then put a simple on/off switch from connection 5 to the test light? Is it really that simple? My current car is an 96 Turbo. I’m trying to diagnose a Electronic Climate Control issue (the dreaded blinking lights).
esl_97_850_T5
On a 96 850 Turbo, these flashing LED tools are used with Motronic 4.3 on pin 3, ECC on pin 6, and Cruise Control on pin 13.
So if you are going to diagnose an ECC problem, the light goes between pins 6 and 16 (not pins 3 and 16 as you mentioned in your question).
For your test light, I suggest a 12V Red LED with in-built 680 ohm resistor.
Here's a list of flashing LED tool alternatives (including Ben850's).
levi_850
Year and Model: 850 2.5 10v '97
Post by levi_850 »
So I'm trying to read my abs fault code, but at my odb connecter there is no wire under #12. Only 1,3,4,5,6,7,13 and 16 have wires under them. Any chance for me to read abs fault codes?
esl_97_850_T5
levi_850 wrote: 05 Oct 2018, 11:52 So I'm trying to read my abs fault code, but at my odb connecter there is no wire under #12. Only 1,3,4,5,6,7,13 and 16 have wires under them. Any chance for me to read abs fault codes?
My notes indicate pin 12 was used for ABS on the 900 and S90/V90.
So don't be surprised if you don't have it on your 850.
I have no experience with using a flashing LED tool on pin #12.
I think that it is *not* possible for you to read your '95 850 ABS with an OBD I style LED flash code reader through the OBDII port (like this thread is focused on) simply because your OBDII port has no pin 12.
Do you have the OBDI box under the hood/bonnet near where the ECM box is in the right front of the engine area? If yes, that would be the quickest way to read your ABS codes initially?
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
Bringing this topic back up: Don't I need a resistor wired in front of the LED? Or are there 12V specific LEDs? Or is the OBD 2 Voltage 5V? I hope one of you guys is electronically better than I am...
1996 855 R,
2010 V70 D5,
esl_97_850_T5
In the volvo_850_diag_links.html page's section that involves
some flashing LED tool links
look for the grey background note titled "Parts used to create jonesrh's flashing LED tool".
That tool uses a 12V LED that has an in-built 680-ohm resistor.
If your LED does *not* have an in-built resistor, you'll very likely need to include an appropriate one.
OBDII voltage between pin 16 and pin 5 (or pin 4) is 12V.
