2003 V70 2.4T Tranny replace?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » 2003 Volvo Transmission Replacement: How Difficult?
precopster
Year and Model: Lots
Been thanked: 128 times
Re: 2003 V70 2.4T Tranny replace?
Post by precopster »
According to the VIN supplied the transmission part number should be 8602050.
Vida states that you have a B5244T3 engine.
The valve body part number matching your transmission is 30713190.
If you go to Tasca parts and search, the online price for the trans is $2, 759 The transmission part number supercedes to 8251406.
lizardheart
Year and Model: V70 2003 230k
Post by lizardheart »
Cool, thanx very much for that info!!
So is that then a rebuilt transmission, I assume?
If so and that's basically what the trans parts cost is, then it becomes an issue of how difficult it is to drop the old one and put in the "new"…..is anyone aware of a tutorial or video showing this procedure, or any opinions on doing it myself, assuming a fair amount of experience and good sense, (and audacity)?
2003 V70 2.4T
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
precopster
Transmissions from Volvo are rebuilt. That's a great write-up for a home DIY without a garage hoist and is doable with a couple of spare weekends.
The box can be dropped separately without the need for engine removal however there are some specialist tools required. A hoist lifting the entire vehicle from underneath would be best however the vehicle COULD just be lifted at the front with a cherry picker to allow clearance. The write up's on Vida. I'll attach it shortly.
lizardheart
AWESOMENESS!!
Thanx guys!!
2003 V70 2.4T
lizardheart
Well ok, yeh, if the tranny can be dropped instead of lifting the whole engine and tranny UP and out, then that might make it something I'd do….that write-up that's referenced in this thread is intense, at least for me, and I won't be doing that…..
2003 V70 2.4T
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
These instructions are for the XC, but I would think they are largely applicable to your FWD....
Removal:
http://www.v70xc.com/0/resources/how-to ... Remove.pdf
Installation:
http://www.v70xc.com/0/resources/how-to ... nstall.pdf
lizardheart
Wow, those are great! Thank you!
2003 V70 2.4T
precopster
These docs are searches from Vida.
I don't think they differ from the other docs supplied above.
AW55-50SN Fitting.pdf
(1.61 MiB) Downloaded 733 times
AW55-50SN Removal.pdf
(1.67 MiB) Downloaded 386 times
lizardheart
So, do you feel that replacing the valve body thing is fairly successful at taking care of most tranny issues, or is it hit and miss, or depends on…? I could describe what's happening with me more thoroughly I guess, tho what I started with is pretty much what it does, does that tend to be what happens when the valve body thing starts to go?
I'm kinda feeling like that whole engine/tranny thing is a bit past me….
2003 V70 2.4T
