https://www.matthewsvolvosite.com/forums ... =1&t=66400jblackburn wrote:The thermostat should fail in the open position - nothing should be overheated. The ECT usually throws a code when it notices that the engine is never warming up to temperature.
I've blown 2 heater hoses in cold weather. One at the crimp; the other the brittle plastic connector to the heater core junction box failed.
Don't forget about the little turbo coolant feeder hoses!
850 or aged white blocks cold weather.
Ben850
- Been thanked: 7 times
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
So the consensus is that they will fail in the open position no matter what? AFAIK that's true on these. Good design there.northernlights wrote:The Wahlers that I have seen fail have broken at the top strap, and as a result failed open. To me it looks like they were designed to fail open, because having a thermostat fail closed is very bad.cn90 wrote: - When the tstat prong breaks, the tstat opens sooner because the spring tension is no longer there ---> engine runs cold.
When I was a kid, we had one stuck shut on a Saab 900, but I have no idea what the T-stat actually looked like.
'98 S70 T5
2016 Chevy Cruze Premier
- Has thanked: 311 times
- Been thanked: 817 times
Are you speculating or you have actually seen this happen, or read about it or something? I think it is not the case ...jblackburn wrote:... The ECT usually throws a code when it notices that the engine is never warming up to temperature. ...
In addition to my own cars (3 broken stats as mentioned), I can't recall a single thread reporting an ECT code as a result of a failed tstat on their Volvo. Granted, I don't always recall so well ...
jblackburn
It has happened EVERY time I've had a bad thermostat (3) in the S70 and ignored it til I could get around to changing it out a few days later.erikv11 wrote:Are you speculating or you have actually seen this happen, or read about it or something? I think it is not the case ...jblackburn wrote:... The ECT usually throws a code when it notices that the engine is never warming up to temperature. ...
Seen it happen in other threads as well.
'98 S70 T5
The voice of experience! Good to know, thanks for the follow up.
- 556 Views
Last post by volvolugnut
- 4317 Views
Last post by westu37
- 4747 Views
Last post by dcm0123
- 1778 Views
Last post by cn90
- 17 Replies
- 1349 Views
