B5234T? N Blocks!
GranTouringRacing
Year and Model: 1998 V70R AWD
Has thanked: 3 times
Post by GranTouringRacing »
So as a Volvo tuner i have been building a load of forged engines recently and one thing that puzzles me that i cannot get a definitive answer on it with the timing belts.
So i’m talking about the Motronic Blocks here 94-98 with the 850’s B5234T and then the B5234T3/4/6 used in the C/V/S70 p80 cars.
The 850’s B5234T blocks use a belt with the Aisin spring loaded tensioner and the later B5234T3/4/6’s use the more common mechanical manual adjuster ones.
Yes the belts are different lengths, but thats because of the tensioners being very different and the blocks are identical with the same bolt holes on them both so the question is can you use the later (easier to change) kit on early engines to make them essentially B5234T3/4/5’s as they are all getting forged internals anyway.
I personally can’t see any difference but i’m being told it’s not possible but i think it is?
Obviously i know the normal response is keep it the same and do what the Volvo part numbers say, but there is more available for the later engines!
Thanks in advance!
GranTouringRacing
I didn’t realise i could add pictures lol!
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
On a different forum I believe user dougy could install the new tensioner on the old blocks by grinding a bit of material of the block. He did this as he was building a R version engine with a 2.3T block. However which tensioner exactly, I can't say. Take my info with a grain of salt of course since I could be misleading you.
GranTouringRacing
What other forum was that dikidera?
dikidera
Post by dikidera »
swedespeed
GranTouringRacing
Pretty sure all those old forums are gone, i tried to look at the earlier and the links are now gone?
Has thanked: 2207 times
Been thanked: 1852 times
If you look at the positions of the 2 tensioners, the earlier tensioner pulley sits higher on the side of the block. So if there is no hole for the manual tensioner already in the block I can't see how they are exchangeable? Certainly the belts look like different lengths.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
GranTouringRacing wrote: 18 May 2023, 14:40 Pretty sure all those old forums are gone, i tried to look at the earlier and the links are now gone?
www.swedespeed.com
is active.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
misha wrote: 18 May 2023, 17:34 Try on www.volvospeed.com
It's gone. I registered last fall and never went back until about a month ago and found it doesn't load.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
