Fix what needs to be fixed...Turbos have wiring harness issues, due to heat, but NAs last much longer.mhgreen wrote:"new" engine wiring harness.
1986 240 DL Fuel injector connector issue
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
You can buy a brand new harness here, for ~$400. Good deal, and probably better wiring than OEM, but I don't think it is necessary in your case.mhgreen wrote:I think I am going to look into acquiring a "new" engine wiring harness. There is a lot of deterioration on mine, and from my research this is a common issue from '85-'88
Did you peel back the wire loom/cover/whatchmacallit to look at the actual wires going to the injector connector in question?
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
No, I didn't want to mess with them more than I had to. I wrapped whatever was exposed in electrical tape and left them alone.mtd240 wrote:
“Some cannot loosen their own chains and can nonetheless redeem their friends.”
rgk
- Year and Model: Gray 88 245
- Has thanked: 1 time
Your injector resistance should be 16 ohms. Set your ohmeter to the closest setting without going over (mine, for example has 200, 2k, 20k, and 200k and I would thus choose 200), and put one probe on each injector terminal without letting them touch together.
Yes, the injectors can turn. Yes, this sounds like a connector issue. Perhaps you can find a connector at a junkyard and splice it in. But first, have you tried simply cleaning your terminals on both ends?
rgk -- was dickdeadly
Just tested the fuel injectors. Each injector registered at 16.3 on the multimeter.rgk wrote:Your injector resistance should be 16 ohms. Set your ohmeter to the closest setting without going over (mine, for example has 200, 2k, 20k, and 200k and I would thus choose 200), and put one probe on each injector terminal without letting them touch together.
I have cleaned the terminals, yes. I am avoiding replacing the entire wiring harness, so I am interested in "simply" replacing the connectors themselves. That being said, I am not familiar with splicing, soldering, etc. This is where I would need some guidance.rgk wrote: Yes, the injectors can turn. Yes, this sounds like a connector issue. Perhaps you can find a connector at a junkyard and splice it in. But first, have you tried simply cleaning your terminals on both ends?
Great video. Thank you. I ordered replacement connectors on Ebay, and I plan to do this job soon. I was wondering… Is there a way to use the multimeter to test the connectors for resistance?
I replaced all the fuel injector connectors using heat shrink butt connectors. I now can move the connectors/wires and the car doesn't change it's idle or begin to run rough.
This was my first experience splicing, crimping, etc. I am glad I now have the tools and knowledge for future electrical work under the hood. Thank you all for the guidance here.
- 414 Views
- 427 Views
Last post by scwd1
- 30 Replies
- 5951 Views
Last post by mhgreen
- 1580 Views
Last post by 93Regina
- 1827 Views
Last post by danielb314
