Fuel Injector Wiring Connector seal... '98 v70 Topic is solved
dalel
Year and Model: 1998 V70
Has thanked: 29 times
Been thanked: 7 times
Post by dalel »
Need two of the white rectangle seals that go between the fuel injector and the wiring connector. Can't even find a picture of these anywhere on the 'net. Where/how can I get some of these? Or, are they part of the injector or part of the wiring connector? ...Dale
v70 FIseal.jpg (21.65 KiB) Viewed 426 times
dalel
Post by dalel »
Bought some really cheap EV1 compatible connectors that appear to have these seals in them. I'll pull the seals out of them.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Was going to say they are part of the connector so try a junkyard etc. Glad you found something!
Has thanked: 1609 times
Been thanked: 4064 times
I can send you some if you get stuck. I have two injector wiring harnesses from junk cars
