2000 V70XC cannot accelerate, wrong gas?
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Etm for sure. Light was on already so you know there's a problem with that combined with the low idle and shaking. The abs module won't have any bearing until it degrades enough where it's no longer supplying a speed signal to the tcu, then the trans will go into limp mode.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Mine went into on-and-off limp mode for months before the ABS module went. It would be fine for days then be a problem or it would limp for several miles and stop. ABS module cured it. When the ETM went it would sputter and lose power but mostly it would surge at idle. That also went on for months and the surging got worse and worse. Then finally last January on the coldest day of a New Hampshire winter it died altogether. But I never had ETS/ABS lights as the ETM went bad. Never even had a Check Engine light go on.
- 990 Views
Last post by Richard99
- 959 Views
Last post by muddblood
- 2047 Views
Last post by FLXC90
- 4497 Views
Last post by adrish
- 1196 Views
Last post by alschnertz
