1999 Volvo V70 XC AWD rear wheel not norking anymore
- Year and Model: Many Volvos
- Been thanked: 76 times
The viscous coupler only pertains to the rear wheels. It is mounted on the car directly between the prop shaft and the rear differential.
The right front axle goes through the transfer case but it isn't driven by the transfer case, it is driven directly from the transmission.
There is a splined collar that fits between the transmission and the transfer case that transfers power from the transmission to the transfer case. The right front axle goes through the center of that collar but the right front axle's splines go directly into the transmission itself. Other than providing a seal to keep the transmission fluid from running out of the transmission the transfer case / bevel gear / angle gear, the prop shaft, and the viscous coupler have nothing whatsoever to do with the drive from wheels.
In short, both front wheels are driven directly by the transmission.
- 987 Views
Last post by voom8
- 1329 Views
Last post by tyguyc
- 26 Replies
- 5609 Views
- 573 Views
Last post by CIK7
- 1798 Views
Last post by RickHaleParker
