1998 V70r Passenger seat control - no movement
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Odds are you've got a bad switch. They are a common failure item.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Hold the switch in one of the directions and try to give the seat a light 'bump' backwards. My 99 sometimes sticks a bit and that gets it to move. Needs lube, obviously.
- E Showell
Switches also sometimes work on the memory presets but not the individual position control switches. It can be interesting engineering the correct seat position using short blips of the memory switches.
'95 855 auto (sold)
'95 855 auto (sold)
I've tried to hold the button and move the seat in the past and again this weekend. no budge whatsoever. i mean none. And i gave it a good effort. i did lube the rails a bit and sprayed into the parts I couldn't reach. That tricked works on the driver side but on the passenger side I get zero budge.
On the driver side I have preset position 1 programmed all the way forward and position 3 all the way back. nice little life hack there. Moving forward/backward with the button alone maybe works 10-20% of the time. The presets work like a charm and up/down seat bottom and tilt on the backrest all work. Just forward/backward sticks.
1988 740 -- Long gone
1998 V70r -- Current daily driver
2004 S60 -- Magically turned into a Toyota Sienna
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
My switch didn't work for a couple of operations no matter how hard I pressed. I opened it and cleaned the buttons with WD-40 and it fixed the problem.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- 2128 Views
- 1771 Views
Last post by Sommerfeldt
- 1879 Views
Last post by rspi
- 46 Replies
- 9459 Views
Last post by Rattnalle
- 16 Replies
- 3722 Views
Last post by xHeart
