'99 S 70 Rear Shock Change
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I am still a bit of a devotee of the blue point wrench (a/k/a torch).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
abscate wrote:Make sure you split the whole width or else it is most dissatisfying. ...
Not sure what this means. The nut pretty much falls off the thread once it has a nice crack.
E Showell
Post by E Showell »
I was curious about that as well. I should add that the offending nut is a cap nut (as is the replacement I have for it). I'm not sure that should have any effect on the approach though.
'95 855 auto (sold)
Has thanked: 1613 times
Been thanked: 4078 times
As long as you crack the whole side of the nut.On old VW suspensions, replacing the front axle, the axle bolts were notorious for cracking incomplete and the untracked part would still hold onto the threads for dear life.
I think you can get a nutcracker on the rear shock nut cleanly. Disclaimer - mine just turned off with a 18 inch breaker nice and easy.
Don't forget to play Tchaicovsky when using a nutcracker for inspiration...
E Showell
Post by E Showell »
I was using a 30" plumbing pipe home made cheater bar and not getting enough torque to loosen it. Back at it in a bit to put our collective wisdom to the test. . .
'95 855 auto (sold)
Heat that sucker for 2 minutes. The hottest part of the propane torch flame is right the tip of the inner light blue flame core. Heavy leather gloves and try not to smell the burning rubber.
Dont stand the torch back up under the plasic gas tank or you won't be reposting.
E Showell
Post by E Showell »
So I got out the brand new, never-been-used before Autocraft brand "heavy duty" nut splitter (lifetime warranty) -- anyone see where this is going? . . . and after about three turns with my 19mm socket, both sides of the nut splitter --the ram and wedge -- promptly broke off. In case you hadn't guessed -- Made in China.
'95 855 auto (sold)
Since your nuts weigh the same as duck, they are a witch...
Burn it....burn it.....
E Showell
Post by E Showell »
Tried heat. No joy since nut is fairly well-rounded by now.
'95 855 auto (sold)
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hi,
Up next: Dremel + heavy duty cutting disk + ten minutes :-)
