2000 S70 Brakes and General Questions
- Has thanked: 1611 times
- Been thanked: 4074 times
If they aren't rusty/Knarly or getting hot, they are probably ok. It is possible to freeze on one side and often that's on the inside where you can't see without rolling under
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Grooves in the rotors are usually caused by rocks getting caught in the pad, no big deal unless it is noisy. Someone could take the pads off and clean them and put the pads back on.
The parking brake problem can only be solved by removing the rear rotors, you need to find out why they don't work. It is possible that the pad material on the shoes is delaminating. New shoes are reasonably cheap even at the dealer.
Klaus
Can I use a Nissen evaporator core and Air Products AC compressor if I need to get them replaced? Or are they one of those genuine Volvo parts only kind of product?
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
