2005 xc70 engine system service required, brake failure
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
You can do it under one day, if you have all the tools and drop exhaust as a first thing. Working around exhaust and driving to shop to get those pulleys one by one took a major part of that day. I did the job with car sitting on 4x 6000 lbs RhinoRamps, space is adequate, and you can just put exhaust and driveshaft aside on floor. I'd say, can be done in 4-5 hours working slowly.
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
great, thanks.vtl wrote:You can do it under one day, if you have all the tools and drop exhaust as a first thing. Working around exhaust and driving to shop to get those pulleys one by one took a major part of that day. I did the job with car sitting on 4x 6000 lbs RhinoRamps, space is adequate, and you can just put exhaust and driveshaft aside on floor. I'd say, can be done in 4-5 hours working slowly.
is it ok to drive in this condition until the pump is replaced?
vtl
Yeah, I drove around a month when I clearly realized that the pump is dead. It was causing strange effects at least few months before that, until I started to suspect AWD.mrscullini wrote:is it ok to drive in this condition until the pump is replaced?
mrscullini
great, thanks again for all the good info.vtl wrote:Yeah, I drove around a month when I clearly realized that the pump is dead. It was causing strange effects at least few months before that, until I started to suspect AWD.mrscullini wrote:is it ok to drive in this condition until the pump is replaced?
- 4800 Views
- 1975 Views
Last post by psamanni
- 1140 Views
- 25 Replies
- 18660 Views
Last post by ADriggs26
- 11 Replies
- 6431 Views
Last post by naperboiler
