fuel pump access hole cut. Pump issues
Has thanked: 2199 times
Been thanked: 1852 times
If you want to look at what your system looks like, look at my old post here, where you can see how the top of the tank is laid out, and there are 2 fuel regulation devices. A fuel pressure valve and regulator.
https://www.matthewsvolvosite.com/forums ... =1&t=69887
Acjlarsen
Year and Model: 2000 volvo v70xc awd
Post by Acjlarsen »
I've rectified my mistake. I got the lift in the left side tank back in and wired. I then bought an air nibbler and cut the hole in the correct side, put the new pump in plus new seals on both sides. No leaks. Now to patch the holes. The car starts right for the first time in a year. Heres a pic of the hole i should have cut the first time Image
Acjlarsen
Post by Acjlarsen »
Theres the patch i came up with.
Acjlarsen
Post by Acjlarsen »
It might look like it but that isn't a piece of copper
Has thanked: 1609 times
Been thanked: 4065 times
Are you going to weld that or Seal with JB or similar product?
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
scot850 wrote:If you want to look at what your system looks like, look at my old post here, where you can see how the top of the tank is laid out, and there are 2 fuel regulation devices. A fuel pressure valve and regulator.
Great thread! What a pain that set up is. wow!
'00 S70, '04 S60 and the never ending quest for Stage Zero
