98 S-70 GLT need to r\r waterpump & Timing belt
Paul240480
- Year and Model: V70SE Auto. V70T5SE.
Soz, ignore posted in error
Paul240480
http://www.gitessouthbrittany.com
Paul240480
Did my N/A 20v a few months back.
I got an SKF kit including waterpump. This did not contain the hydraulic tensioner, so got this from Parts for Volvo & it is a Professional Parts Sweden one. Aux belt tensioner is a Febi-Bilstein.
You do not need a special tool to release the aux belt. Just a bit of strong metal cut to fit in the slot on its tensioner, then use an adjustable spanner as a lever.
Once I had set my timing marks, I locked my cams like this:
Paul240480
Just did this yesterday in the drive way. Timing marks sometimes hard to find, but rotate to see the crankshaft mark, line up, and timing marks on camshafts appeared. So I marked with white enamel. At TDC (top dead center) number 1 cylinder, no pressure on cams since this is top of combustion cycle, they stayed lined up without any special tool of zip tie. Checked as I got new belt on, and all was fine. Water pump a little tricky to get in, must go from bottom to get it positioned. Always rotate the engine a few times to detect any mechanical interference (read: valves hitting the pistons), then recheck the timing marks. Put it back together, and worked great. Local shop wanted $685 which included the two pulleys, but I checked mine and they were solid. Water pump was $55 and Conti belt was $23, so I saved over $600 on the repair. Now onto the next project...
Thanks...
Chuck
1968 BMW 2002 300K+
1977 BMW 320i 325K+
2007 XC70 149K+
Chuck
1968 BMW 2002 300K+
1977 BMW 320i 325K+
2007 XC70 149K+
Paul240480
Yeh it's a great saving ain't it? My kit was around 200 euros all in. The 'recommended garage quoted over 800 euros.
Paul240480
I received my parts.( h2o pump & tm belt kit) noticed a difference w/ the mech. tensioner. The tensioner in car has dog-eared (bent fingers) that seem to lock it onto engine, the one in kit does not- it has 2 post like a 'V'. Question? Are these compatible or do I have the wrong part? Need to get this resolved soon. Thanks for any info.
1ezliving4ume
- Year and Model: 850 glt turbo 1997
Pictures would help
- 34 Replies
- 5433 Views
Last post by regent
- 754 Views
Last post by cn90
- 1158 Views
Last post by chrism
- 4058 Views
Last post by shiloh51933
- 606 Views
Last post by jonesg
