Rear Driver Side Window Rolls Down But Won't Roll Back Up (using the rear button)
Has thanked: 2196 times
Been thanked: 1850 times
The advantage of the Switch Doctor brand I bought was that it is contactless so removes this major issue with the OE part!
SleeStak69
Year and Model: 1998 S70 T5 5MT
Post by SleeStak69 »
cn90 wrote:- Re removing switch: if you are slow and methodical (wrap a small screwdrive with cloth and go around), you can remove the Master Switch w/o removing the door panel.
- There is a thread on dis-assembly of the switch on clean the RR contact points in forum.
- Re NEW master switch: Volvo OEM is $140.
- However, many here have had success using "Switch Doctor" brand, which costs only $22.50:
http://www.ebay.com/itm/NEW-1998-2000-V ... 0629042986
Should I take the rear one out since that's the bad one and test it with an ohms meter or something before I order the switch? Someone said that if you're doing anything with Window switches that the master switch is always involved. That doesn't mean I would have to order both right?
Pewter Silver Metalic 1998 S70 T5 5 Speed 8)
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
I'd suggest swapping in a fresh master first.
If you still have troubles, you know where to look.
