It sounds like a problem with the clutch. I would start at the compressor with a voltmeter and see if the voltage remains after the compressor quits. If it has good voltage at the clutch but the clutch doesn't stay engaged then it is a clutch problem. If the voltage drops out then the compressor is being told to turn off and that would usually be either a bad low pressure switch or a bad high pressure switch. Those would be the next things to go after with the voltmeter.
98 v70 a/c blows warm
- Year and Model: Many Volvos
- Been thanked: 76 times
- 8774 Views
Last post by dcm0123
- 1279 Views
Last post by olddaddy
- 36 Replies
- 2813 Views
Last post by erikv11
- 3539 Views
Last post by 93ForMe
- 18 Replies
- 8222 Views
Last post by packetfire
