1999 OBD code P1073 ECM1100. Outside air temp sensor Topic is solved
Thanks! Updated thread title to cross reference p code with ECM code forvsearch
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Don't get me wrong but....if you asked for ECM-1100 at first place you would have correct answer:Garaba wrote:ECM-1100, visually verified as having the wire ripped out when I curbed it sometime in the recent past.
http://www.volvoforums.org.uk/showthread.php?t=111644
http://www.volvo-forums.com/t16319-chec ... -turbo.htm
Volvos DO have specific codes and because of that...ECM format codes are 100% correct instead of generic/universal codes in "P" format which can lead you to wrong way.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I don't think the OP had the ECM code until s/he got access to VIDA, just the Pcode which isn't in the P code charts.
I have both in Alldata but there is no cross reference, unfortunately. My AUTEL 800 does give the ECM codes which is neat
JeffHicks
- Year and Model: 1989 240 Wagon,
I had this happen on my '99 V70 a couple years ago.Garaba wrote:I need some help. Volvo 1999 V70, runs great. But I can not get the sucker to pass emissions, I have a check engine light and the code P1073. I can not find anywhere what that code means at all.
It is also the code that is failing me at emissions. When I clear the code, it will come right back in about 20 seconds.
We had clipped a chunk of tire tread on the Interstate, and it had broken one of the 2 temperature sensors on the front air dam. Replaced it with one from a salvage yard, and we were back in business.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
- 566 Views
Last post by JimBee
- 3268 Views
Last post by Sommerfeldt
- 5122 Views
Last post by Raindog92
- 2051 Views
Last post by misha
- 731 Views
Last post by ja564rm80
