P0455 - Should I fix it?
Surfmullet
Year and Model: 2001 Volvo S60 2.4T
Post by Surfmullet »
No. I did not. I didn't want to do any more crawling under the car. I'm old and I get dizzy when I'm lying down underneath the car for long periods of time.
I wouldn't doubt it is the leak detection pump or electrical wiring for the "correct" factory fix.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
The test I mentioned is within the VIDA software. No climbing under anywhere except dash to plug in DICE. Commonly this pump fails and reports a leak. Also I believe there was a software update for this module / pump as it originally detected a fault at too low of tolerance.
I don’t believe restricting your vent charcoal filter should ever be necessary.
Maybe someone near you in WA can assist. I’m sure abscate wouldn’t mind driving from the east coast. :lol:
04s60 2.4
04xc70 2.5t
Has thanked: 1610 times
Been thanked: 4068 times
br0dy519 wrote: 23 Oct 2025, 19:28 The test I mentioned is within the VIDA software. No climbing under anywhere except dash to plug in DICE. Commonly this pump fails and reports a leak. Also I believe there was a software update for this module / pump as it originally detected a fault at too low of tolerance.
I would love to but I’m on the wrong side of the Atlantic eating Danishes.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Don't fix it. Just keep clearing the code to turn off the light.
Unless you live in a place that punishes you have having emissions codes set. Then move to another place!
volvolugnutr
