Do You Really Use Torque Wrench?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Has thanked: 1497 times
Been thanked: 3809 times
Re: Do You Really Use Torque Wrench?
For reference - last time I used mine was on the clutch pressure plate bolts (have to be even) and also the subframe bolts on the P2 - Torque plus angle tightening, also on the driveshaft hub bolts - same thing.
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
It depends on level of experience.
- Newbie: should use torque wrench for everything until they get a feel for torque values.
- Seasoned worker: I have been wrenching for 30 years, so I am like "precopster", I only use torque wrench for critical places like cylinder head bolts, VVT hubs. The wheel lugs: I don't bother with torque wrench, I hand-tighten it until it is snug, then another 45 degrees: been doing this for 30 years.
PS: I have stopped using the click-type, if not calibrated properly, it can be worse than no torque wrench.
I now use only dial-type torque wrench, it is old-school but it works.
jonesg
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
Looked at a digital adapter to indicate torque, stick on any ratchet wrench. It was at HF so I passed, looked like a decent idea if ...if... It works.
Yeah - I think I would pass on that - you can get a decent click Cobalt at Lowes for $60 - keep it in the case and use it carefully and you can get many years out of that. Remember to run the spring down to no tension to store.
coded9
Year and Model: 2007 S80
Post by coded9 »
I do myself. I'm still somewhat of a newbie but here recently I've started to get idea when enough is enough in tightness, especially where I couldn't use one (like my laptop for example where the screws are super soft). Nothing's fallen apart on me yet (still would do it for drain plugs for GP though or anything where precision is more of an concern).
2002 S60 2.4 Automatic N/A (Totaled at 161K)
2007 S80 3.2 N/A 122K
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
I use a torque wrench as much as possible for several reasons:
1. I have zero confidence, based on past experience, of my ability to correctly judge adequate torque. I have run into issues both with using too little and too much torque without a torque wrench.
2. Tightening to a consistent torque, and specifying this torque in instructions, makes it much easier for your procedures to be repeated and for others to be trained. Kind of like having a recipe with precise measurements versus saying "a pinch of this, a bit of that..."
3. You can tell someone exactly what torque you tightened something to, so that you're working with a consistent set of measurements, which can aid in diagnostic discussions.
4. I'm a nerd, and I like to do things to factory spec whenever possible.
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
thebull
Year and Model: XC90 R-Design 2009
Post by thebull »
I`m using torque wrench almost all the time on engine, suspension or wheels.
Flying on 2009 XC90 R-design 3.2L AWD and 2006 XC90 2.5T AWD. Volvo owner forever.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I use the clicker happily. When I have something important to do involving many bolts, I set one screw with a beam-type wrench, set the clicker based on that, then torque all of the bolts with that. This isn't perfect - there's some static friction to overcome before a bolt that was set to a certain torque starts moving again - but it gets you pretty close, and, with most fasteners on a car, pretty close is good enough if it's consistent.
If I have to do head bolts, I'll take my time and use a good wrench, sure. But for most applications, this method strikes a good balance of accuracy, consistency, and convenience.
Post by cn90 »
I like the cooking analogy.
New chef measures everything, how many cups, teaspoons, tablespoons etc.
The seasoned chef goes by "eyeball" and "taste"...lol.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
edited
