For some reason I cannot post a video of what it is doing, but here is a link to a you tube video where it sounds almost exactly the same. There fix was the fuel pump relay.
2001 Volvo S40 Stalled out and now won't start
ambermic83
- Year and Model: 2001 S40
- Has thanked: 2 times
ambermic83
Ok here is the video of my car I just uploaded it to you tube so you could hear it
jefe
- Year and Model: 2001 Volvo V40
- Been thanked: 3 times
Fuel pump fuse is the blue 15A that's paired with the red 10A fuse, just to the right of the yellow clip that holds 3 fuses.
Might as well check all of them though.
ambermic83
I will watch those. I checked the blue fuse I'm looking for the relay? From what I have read I should have one numbered 103 or similar but I can't find that anywhere and I have the owners Manuel but it does not mention it. Does this model have one?
ambermic83
On another note running through some of the no start videos I did use a light tester to the fuse box with key in on position some light up but others in the box did not. Is that normal? The fuel pump fuse did not light up but we can hear it when we turn key on my husband got down there and checked.
jefe
This is exactly why these volvo's are hard to work on. The manual I have is pretty worthless too and information can be hard to come by.ambermic83 wrote: ↑13 Jun 2018, 18:48 I will watch those. I checked the blue fuse I'm looking for the relay? From what I have read I should have one numbered 103 or similar but I can't find that anywhere and I have the owners Manuel but it does not mention it. Does this model have one?
My wife's Volvo isn't at the house right now, otherwise I would look for it, but according to FCP Euro, this is what it would look like (possibly black, not green). You can always 'ask a question' on this link as well. They usually reply within a day.
https://www.fcpeuro.com/products/volvo- ... 70-9494787
Also try removing the panel on the interior driver side where your knees would be when driving. There's another fuse panel under there as well as some relays I believe.
jefe
I've never used one of those. It could be the tool, who knows. I just pull the fuses and inspect visually. The ones in the engine bay you can just use a flashlight to see if any fuses are blown without having to pull them all.ambermic83 wrote: ↑13 Jun 2018, 18:54 On another note running through some of the no start videos I did use a light tester to the fuse box with key in on position some light up but others in the box did not. Is that normal? The fuel pump fuse did not light up but we can hear it when we turn key on my husband got down there and checked.
https://static.cargurus.com/images/site ... x1200.jpeg
ambermic83
I think all mine are black and they all look alike under the dash I did look still did not see one labeled fuel relay. But all the ones that are in my car are black not green so I guess ill keep looking
emtor
- Year and Model: 2002 V40
The fuel pump relay is named system relay by Volvo, so don't expect to read "fuel pump relay" inside the relay/fuse box.
https://www.2carpros.com/questions/volv ... -fuel-pump
Remember that this relay serves two functions: -Priming (two seconds when ignition on, then stops) and always on while the engine is running.
There should be a similar relay in these cars also. I think it is the A/C relay but I'm not sure. Perhaps someone here can clarify. Pull both relays and swap them.
If your fuel relay is shot the A/C shouldn't work and the fuel pump should work.
