1999 AC job. Rein over nissens, adjustable orfice valve
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
I have installed several VOVs in different vehicles. Maybe a dozen. On one vehicle it worked and is still installed. On many I had to remove and put the standard one in. On 4-5 it is still installed but the system didn't seem to be any colder. The original promise is that the VOV will fix the issue where due to low engine and resulting low compressor pumping rate, the pressure difference in system doesn't encourage good evaporation of refrigerant. I harp on here about NEVER idling engine when you are diagnosing or charging a/c system due to low compressor efficiency and the pressures being out of range for any decisions. Volvo instructions for a/c service is engine speed elevated. But back to the issue here, I don't use them any more because they have inconsistent results.
- Has thanked: 1611 times
- Been thanked: 4071 times
The 'five river mechanics' here are awesome for combination of experience and willingness to share.
Thanks, jimmy.
Thanks, jimmy.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
A TXV would fix all of this.
I can tell when in traffic the condenser gets heat-soaked, even with RECIRC on (which it always is here). The refrigerant is still a vapor at the orfice. Much like a spray can when it gets empty; rather than spraying ingredient in a nice pattern, it just 'spits'.
I'd advise against "variable" as well....
M1 10W-30 HM
M1 10W-30 HM
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
And the no variables have it!
2023 Lexus RZ450e -66k
- June
- Has thanked: 523 times
- Been thanked: 261 times
abscate wrote: 19 Jul 2018, 14:19 Is it cruel to make my 87 year old Mom the Guinea Pig on this, June??
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
Wrap up...
We used the Nissens evaporator and the standard Volvo orfice valve, aftermarket.
Rein for the drier.
I got the best AC delta I’ve ever done, 43F at 83 F ambient.
Rein for the drier.
