There is an assortment of capacitors that have about 200 capacitors and about 15 of each of the needed ones for about $10 Amazon Prime. My issue was that I needed to use the car and a relay was available locally, but I'll fix the old one.jreed wrote: 21 Jul 2018, 05:54 I had good luck buying the fuel pump relay capacitors from DigiKey. For small orders they will ship good old USPS for a reasonable price (I think it was $2 or $3 for postage).
When I replaced my capacitors, I also noticed that the solder joint between the circuit board and one of the relay pins was cracked. You might want to inspect yours for this type of damage and repair if needed.
1998 V70 will not start - apparently no fuel.
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- Eddystone
I usually get my parts from FCP and they get to me within two days via the free UPS. When you're below the free shipping level, shipping is about $10, so I only order when I have enough to get free shipping. In this case, it was on a Friday and an order wouldn't have shipped until after the weekend which would several days before I got the part. Since Advance Auto Parts had one in stock at their nearby East Coast Distribution Center, I bought it there, and am back on the road ready for my vacation. Under other circumstances, I'd go to FCP.
- Eddystone
Replaced the caps, and the original Volvo relay now works fine.Ozark Lee wrote: 20 Jul 2018, 18:51 The capacitors are 22 uF and 100 uF electrolytics (one each). 25 Volt or greater but you have to watch the diameter on the higher voltage ratings.
Any good electronics supply house should have them if you have one locally. You can always get them through places like Digikey or Mouser but the freight eats you alive.
- Eddystone
Eddystone wrote: 20 Jul 2018, 14:12 Thank you @abscate ! Found the info where you led me, tested with paper clip. Engine starts right up. I'm skilled at replacing electronic components and soldering, but Radio Shack is no more. I have lots of capacitors around but I don't hold out much hope of finding and identifying the right ones.
- 1091 Views
Last post by jonesg
- 2618 Views
Last post by Chuck W
- 2178 Views
- 830 Views
Last post by jmartin919
- 13 Replies
- 3088 Views
Last post by loosenut
