Thank you. Im currently checking. I just replaced one hose near the gas tank this morning. I'll continue to check. Thanks a lot.
Oh. Anyone with a post probably with pictures as to How to Remove the Lower Thermostat Housing ?. It broke and Leaking all coolant.
Thanks in advance
What is this hose connected to ?
Update: just saw P0440 on OBD scanner. No Check Engine Light. Anyone with insight to this issue ?. Car runs great..but can't pass inspection with this code.
Checked OBD..Only 3 are Ready and Never get cleared whenever I tried to clear with the scanner. (The MIL, FUEL and Misfire ). Others continue to show Not Ready. Ive been driving car around just so the others might get ready but No Luck. Only P0440 keeps clearing and coming back. Any ideas as to solving this problem and get the car to pass Rhode Island Emission inspection which is due by end of August ?
- Been thanked: 4071 times
Where is P440 showing on dash?? Snap a photo.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Thanks.. Problem not J Hose. Already checked. All ok. Only I am yet to check around the Gas Tank. I read..some hoses down by the rear passengers tire leading to the tank may also get cracked. Ill find out tomorrow. Thanks anyway.
- misha
Could also be a purge valve.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
A brand new Purge valve
(Botch) was recently installed
The problem might have been resolved yesterday after just tightening a seemingly loose hose connection from the newly installed Cold Air Intake leading to the MAF.
I drove the car around and later found out there are now 4 monitors good : MIL=Off, MISFIRE=Ready. FUEL=Ready. CCM=Ready. No Codes.
I think its just 1or 2 more monitors that I'll need to be ready as in Rhode Island where I live, at least only 5 monitors required to be ready in order to pass inspection. I'll drive around Again after fixing a leaking Coolant I believe from a broken Lower Thermostat Housing( Already ordered).
Thank you.
Thank you.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Most cracks in the vacuum hoses can only be found with a smoke test.
- 542 Views
Last post by erikv11
- 596 Views
- 3539 Views
Last post by Gnarledbark
- 2361 Views
Last post by Orchid70
- 4584 Views
