Unknown no start possible fuel issue? Maybe purge valve Topic is solved
BlackBrick
- Year and Model: 1997 850R
- Been thanked: 3 times
have you checked your fuel pressure while cranking?
BlackBrick
Worth checking fuel pressure so you can eliminate fuel as the issue. (You'll need an angled attachment to a fuel pressure gauge to reach that schrader valve on the side of the fuel rail.)
fuel pressure regulator stuck open? That would prevent any fuel pressure building up.
Unlikely to cause a no-start
Aggnizzab
- Year and Model: 1995 850 turbo
- Has thanked: 5 times
UPDATE THROTTLE POSITION SENSOR WAS MY ISSUE
Aggnizzab wrote: 10 Sep 2018, 12:57 Ok so I ran with the fuel light on for about 30 miles my fiance put gas then we got a no start condition. About 4 hours later went to the car to check it out myself and she fired right up. Then got home she refired several times no issues. Next day fires right up get to appointment about 30 minutes away stay at appointment for 2 hours then go to start... No start . Have her towed home the next day she starts but dies right away. I have check the valve on the fuel rail I have a steady clean stream, I hear my fuel pump, I feel and hear my fuel injector relay and the the pump relay I replaced the fuel pump fuse, fully charged the battery and I just keep getting the same the a start then stall out then no start. I do know I have a bad 02 sensor. And I just rebuilt the fuel pump relay harness thingy. I think purge valve maybe but don't know the proper way to check or locate it ! Any thoughts or advice is much appreciated. I am also working on a budget and a self taught mechanic lol self teaching I play mechanic
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Like allready mentioned...TPS alone can't cause no start condition,but in this case...it's could be from combination of bad o2 & tps.
It seems that both of them failed...can.
On the other side...it could be that TPS failed in mid range or high range position and flooding the engine on start-up in this case...since throttle is phisically closed.
I would say that it would start with TPS connector disconnected in this case or at least...with gas pedal on the floor while cranking.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 11 Replies
- 2088 Views
Last post by veektor
- 7355 Views
Last post by Seaway
- 1134 Views
Last post by Volvo S80
- 29 Replies
- 19604 Views
Last post by bmdubya1198
- 12782 Views
Last post by stavri
