Wheel bearing on 2004
Has thanked: 1611 times
Been thanked: 4075 times
Just open the box at the counter and make sure you are getting what you paid for.
Its an evil world out there sometimes.
SKF - didn't they start a car company somewhere??
:lol: :lol: :lol:
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Thanks Superhernan. I keep getting notices from Wikipedia every year to contribute to this great resource. Hope it sticks around.
From Wikipedia: "Assar Gabrielsson, SKF sales manager and Björn Prytz, Managing Director of SKF were the founders of Volvo AB in 1926. In the beginning, the company functioned as a subsidiary automobile company within the SKF group.
SKF funded the production run of the first thousand cars, built at Hisingen in Gothenburg, beginning in 1927."
Joelfixesstuff
Year and Model: 2004 XC90
Post by Joelfixesstuff »
Now I've run into a problem. Yay.
Ordered the axle bolts/drivetrain bolts/SEMS screw (whatever you call it...depends on where you look!). Should be no. 4, pictured here: https://usparts.volvocars.com/a/Volvo_2 ... 71951.html
Ordered them from FCP Euro, which I'd heard good things about even though I haven't used them before: https://www.fcpeuro.com/products/volvo- ... l-30776055
Problem is, what they sent me looks nothing like what I removed: Image
Did I order the wrong thing? Did I order the right thing and they sent me the wrong thing?
Also...from everything I've ready, replacing that bolt is critical correct?
They also sent me wrong bolts for connecting the hub assembly itself. Is replacing those four bolts critical, and does anyone know the correct part no?
Finally...while I'm at it, I was also reading today that changing the bolts that connect the brake caliper to the bracket is a good idea. Yay, or Nay?
Sorry for all the questions...just super frustrated I got this far to hit a roadblock.
precopster
Your picture shows CV joint retainer bolt X 2 different types (early and later) You need the later type (small)
I've never replaced the brake caliper bolts. Just a good torquing is all that's needed. It's up to you if you want to use a thread lock compound.
I re-used my bearing bolts on our XC90 2006. With a good tug on them with an extension bar I have no fear they'll come loose. If you're not an experienced wrencher I would advise replacing them.
This is what you need: https://www.fcpeuro.com/products/volvo- ... hub-983072
Joelfixesstuff
So on the hub assembly bolts, I ordered from the link you sent. What they sent looks different than what I pulled out. Same length, but threads go all the way to the head, and more importantly (though it may not matter) the head is a couple mm bigger on the new ones. Image
So to be clear...you feel like the axle bolt is fine to reuse if I get it nice and tight and follow the torque specs carefully?
precopster
They're stretch bolts so when you tighten if you feel any lightening of the load on your hand they are stretching too much.
That's why you're better off with new ones tightened to correct torque.
I do like the originals with the thicker shaft. Why does everything have to be cheapened when it's a replacement item? :cry:
I don't think an extra couple of mm is going to foul anything, just check it once it's all torqued up.
Joelfixesstuff
Thank you! Do you by any chance have a link to where I can buy the shorter axle bolts that are appropriate for my car?
precopster
I may be wrong but I think you can use the longer bolt in place of the shorter one. The shorter one is a anti-pinging type to prevent that ringing sound upon take-off.
On an aftermarket CV axle I had to use the longer type as the offset wasn't correct for the shorter one.
Joelfixesstuff
Interesting. If I use the longer one, should I re--use that rubber part, or just put in as-is?
