car won't start after completed cylinder head and timing belt replacement
Jaz
- Year and Model: 2002 s80 2.9 non tur
- Been thanked: 8 times
I checked for any codes and it said ignition advance timing cylinder one circuit not set right something to that effect can someone please tell me what that means and did starter check it said check connection can ::) these issues be cause of car not starting please help
- SuperHerman
- Been thanked: 207 times
Stop and check your timing. Sounds like it is not timed correctly. This will cause a non-start.
Once you have confirmed timing is correct proceed by checking your alternator and starter cables (plus any grounds you may have played with).
Report back - but I think you messed up on the VVT timing set.
Jaz
i jst try to start car again did diagnostc it said crank is normal 11.5 volt 1oo%ms & 100% smethng else can' quite remember does that indicate the timing is good and don't think getting any sparks from plugs checked cylinder 1&2 all other connections seem to be tightly connected sensors also told me to charge battery what the issue for not starting
- RickHaleParker
- Been thanked: 980 times
Check the fuel line to the fuel rail. The retainer plate on my 2.9 bent under pressure and started leaking.
Active
Past
Past
Jaz
ok will do cause yesterday redid the camshaft timimg marks as well the crank shaft check for sprarks from plugs positive gttin fire recheck all connections every thing connected same as taken off and all wire plugs fully tight connected really discourage rght now jst want to hear my car start up its a great car and was running perfect before i let the belt from serpertine get mess up and that got caught up in the timing pulleys i look on top of gas rail on intake manifold but really did not knw wht was looking for can u tell exactly how the retainer plate lookif u hav a image would be great help
- RickHaleParker
Jax: We have posting standards at MVS.
If its not worth your time time to write it clearly. Why should anybody else invest time in it .....
Active
Past
Past
- 2026 Views
Last post by benpineapple
- 13 Replies
- 8479 Views
Last post by lifeofgold
- 23 Replies
- 17820 Views
Last post by jonesg
- 302 Replies
- 46922 Views
- 20 Replies
- 5312 Views
Last post by nickelghandi
