Hesitation on WOT (V70 2.0 T5 AWD 1997) Topic is solved
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Nope to both of these questions.
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Check ALL the vacuum lines 1st before you go further.
What about that fuel you are using?Bio fuel with high percent of ethanol?
It's weaker than standard fuel you should use.
Turbo or non turbo cars need our european premium bmb 95 at least.
Fill the next tank with premium bmb 95,remove negative battery cable for 15 minutes in order to reset old fuel trims and start with that.
With fuel you are using ecu will need to compensate by changing the fuel trims and ignition degree angle to keep the car running at it's best.
It will run with weaker fuel but it will run optimaly,making some compromises between power and consumption.
https://fuelandfriction.com/weekend-war ... -you-know/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1610 times
Been thanked: 4069 times
We did have this same problem solved by a transition from new Bosch yo new Volvo OEM spark plugs
Fiodor
Post by Fiodor »
I've changed my fuel and I've replaced the vacuum lines going to the BCS/TCV.
Are there any other vacuum lines that I should check ?
I've bought a bluetooth ELM327 (I'll read the codes with (850-OBDII) and I'll try to change the spark plugs next week.
Thanks for your help !
misha
Post by misha »
Pcv system vacuum lines
Fuel tank vent lines
Vacuum tree vacuum ports
Sas system(if equipped) vacuum lines
Brake booster vacuum lines
Fpr vacuum line
Fuel tank cap must be OE and tight untill it clicks
Air filter housing vacuum lines
Right side of intake manifold between ps pump and intake manifold...vacuum elbow
A lot of vacuum lines to check! :D
After changing the fuel to euro premium bmb 95,remove negative battery cable for 15 minutes in order to reset fuel trims.
Perform ecu re-learn procedure after that.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor
Post by Fiodor »
Wow, that sure is a lot of vacuum lines.
Could you tell me what the Ecu relearn procedure is please?
Thanks again
misha
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Fiodor wrote: 25 Nov 2018, 06:26 Wow, that sure is a lot of vacuum lines.
Thanks again
Fiodor - it is not a good strategy to inspect vacuum lines on a 21 year old car - they are old and begin to crumble at this age. Once you go to the trouble of removing them, just replace with new ones. You can see a picture of what why vacuum line looked like here - even though inspecting the parts you can see were looking good!
Fiodor
Post by Fiodor »
DTCs checked !
COMBI :
124 Engine RPM Signal faulty
221 Vehicle speed signal Missing [bad ABS module solders?]
222 Vehicle speed signal too high
ECC :
414 Driver's (or passenger's) side interior temperature sensor inlet fan seized (or open/short circuit or faulty signal)
The 3 COMBI DTCs remain after erasal.
What could be causing these ?
misha
Post by misha »
What is COMBI?
Instrument cluster?
Is your speedometer working?
Manual or automatic transmission?
What scanner/code reader did you used?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
