The fuel pressure from a stock in-tank pump is less than 7 psi.waynegarbo wrote: 20 Dec 2018, 13:47 on un unrelated matter, I scratched the fuel ports on top of another fuel pump sender I'm putting in. will the hoses still seal?
740 Cam Pulley Removal
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
1988 Volvo 760 Turbo Wagon
waynegarbo
- Year and Model: 86' 740 non-turbo
- Has thanked: 2 times
but how about the return pressure port from the main fuel pump? what kind of sand paper should I use to smooth it out?
waynegarbo
lummert what about the return pressure line coming from the main fuel pump pressure?lummert wrote: 20 Dec 2018, 15:06The fuel pressure from a stock in-tank pump is less than 7 psi.waynegarbo wrote: 20 Dec 2018, 13:47 on un unrelated matter, I scratched the fuel ports on top of another fuel pump sender I'm putting in. will the hoses still seal?
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Return pressure line...
Return - come or go back to a place or person
Fuel tank is like a place, and there is a return line coming back to fuel tank
Pressure - is the force applied perpendicular to the surface of an object per unit area over which that force is distributed.
Fuel tank's outgoing line to main fuel pump, would have low pressure, like less than 10psi; and fuel line from main pump to fuel-pressure-regulator would have a higher pressure, less than 50psi. But, the return line from FPR to fuel tank is not generally considered a pressurized line.
- 1505 Views
Last post by XC70Rider
- 30 Replies
- 5841 Views
Last post by mrjay62
- 1014 Views
Last post by 98v70dad
- 2466 Views
Last post by andreivlas
- 468 Views
