Thank you SuperHerman.
I will check to see if i can find the number on the vehicle name plate.
S60 t5 2012 purge valve
Hi jimmy57.
Okay i stripped out the back wheel arch lining to see where this breather/vent pipe is. I found the vent pipe it seems to be open. I gave it a blow with the fuel cap open. It made the same knocking noise and build up pressure. As soon as i stoppe blowing it then released the pressure back out the vent pipe mak8ng the same knocking noise. So i am now very confused as i would think that a straight vent pipe should vent without the knocking noise.unless it goes through a pump.
Any advice from here on?
Thanks
Brian
Thanks
Brian
- 7378 Views
Last post by Seaway
- 1176 Views
Last post by Volvo S80
- 29 Replies
- 19808 Views
Last post by bmdubya1198
- 12843 Views
Last post by stavri
- 1140 Views
Last post by sherry007
