0261203628 is a US spec 850 R with M4.3. No doubt about it.
As to your actual issue, it kind of sounds like you're using the wrong pins... if you switch the two "grounds", you'll have a steady light and no function. Put the + in 16, one ground in 5 and the other in the pin for the module you want to read. There should be a steady light. Put car in ON - light should go out, and you can use the momentary switch for 1 second. Should be light while the switch is pressed, then go out for ~2-5 seconds, then code readout.
- S
LED code reader/ECC help
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Peevarino
- Year and Model: 2009 XC70, 97 855R
- Has thanked: 28 times
- Been thanked: 3 times
I figured it was 4.3. Wouldn’t have been upset if I was wrong.
I’ll give it another go, I wanted to work on it this weekend, ended up rebuilding a leaky oil cooler line instead. Probably less contorting than climate control work, though.
09 XC70 3.2
97 855R
97 855R
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The LED code readers work for reading ECC codes on the '97 850's. It doesn't care whether the ECU is 4.3 or 4.4.RickHaleParker wrote: 05 May 2019, 16:41Motronic 4.4 started showing up in some '96 850s.Peevarino wrote: 05 May 2019, 08:06 I posted in here because it’s for a 97 850, not the 09 I have listed in my profile.
"97 is pretty much the year they moved to Motronic 4.4.
OP, make sure you're connected to the proper pins. The pic in the linked post shows a connection for reading ECU codes (#3), and not ECC codes (#6). I used a 1K Ohm resistor in my set-up and have used in on my '96GLT, '97GLT, and '97T5.
Peevarino
I’m going with the resistor is the issue, double and triple checked I had the right pins.
Time to order some resistors.
Once that’s sorted out, I’m assuming this set up would work fine for abs codes, too? I realized last night my abs/tracs lights don’t light up on the dash.
09 XC70 3.2
97 855R
97 855R
- RickHaleParker
- Been thanked: 978 times
The LED doesn't care but some of the 4.4 have the flash code routine some do not.Chuck W wrote: 06 May 2019, 07:00 The LED code readers work for reading ECC codes on the '97 850's. It doesn't care whether the ECU is 4.3 or 4.4.
He would be better off with a ELM327 and 850 OBD-II. Which was developed for the Volvo 850.
Active
Past
Past
- Chuck W
For engine codes, sure, but for his ECC codes, the LED should be sufficient. I use an BT ELM327 unit for engine codes on the cars.RickHaleParker wrote: 07 May 2019, 19:30The LED doesn't care but some of the 4.4 have the flash code routine some do not.Chuck W wrote: 06 May 2019, 07:00 The LED code readers work for reading ECC codes on the '97 850's. It doesn't care whether the ECU is 4.3 or 4.4.
- RickHaleParker
Got a Windows PC or a Mac? 850 OBD-II will run under the free Android emulator NOX Player.
Active
Past
Past
Sommerfeldt
I for one couldn’t get that app to do diddly squat. Wouldn’t even connect to anything, let alone tell me something useful. So I’m also using my trusty blinky tool.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- RickHaleParker
The BT connect can be touchy. Aleksi Venäläinen has been notified, he going to work on that. Even with that short coming, I find it less work then counting flashes.
Active
Past
Past
- 3268 Views
Last post by Sommerfeldt
- 2468 Views
- 20 Replies
- 4740 Views
Last post by smacknab
- 4898 Views
Last post by CRM
- 355 Views
Last post by jreed
