You are looking in wrong direction, if you hear starter clicking but not cranking, the issue is either starter, ground, battery, battery cable to starter or seized engine.
Put a volt meter across the starter chassis and battery cable on starter. Have second person crank engine while you look at voltmeter. If you have 12+V while ignition is in position 3 and you heard the starter click, that means your battery, cables, ground are good.
Have power, won't turn over Topic is solved
joshdecker
- Year and Model: 2002 V70XC
I think you misunderstood. The starter is not clicking or doing anything. The starter relay, in the fuse box, is clicking when then the key is turned on (relay activating).dj_v70 wrote: 11 May 2019, 16:12 You are looking in wrong direction, if you hear starter clicking but not cranking, the issue is either starter, ground, battery, battery cable to starter or seized engine.
dj_v70
- Year and Model: v70 2003
- Has thanked: 7 times
- Been thanked: 23 times
Ah, sorry, I did misunderstand. Did you isolate issue to PNP? If not, do you get 12V at remote starter wire? If you put 12V at starter solenoid terminal does starter crank okay?
joshdecker
OK...so now I feel really silly....I didn't connect the wiring harness back up to the starter (d'oh!)...so it had power, but no signal to start. That's what I get for working on it in a gas station parking lot!
- 2034 Views
Last post by matthew1
- 971 Views
Last post by Ozark Lee
- 1852 Views
Last post by 93Regina
- 1062 Views
Last post by Roger_850T
- 18 Replies
- 8074 Views
