Wheel bearing Hub puller
Has thanked: 1611 times
Been thanked: 4072 times
You don’t pull the front wheel bearing off the hub.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Mr. Detail wrote: 23 May 2019, 06:28 Thank you all. " oragex" I planned to replace the whole hub with bearing included. About $75 new. With that said do I still need the puller?
I replaced similar one (Optima?) in the donor chassis I got recently. It barely did 20-30k miles. Buy Volvo or FAG.
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
abscate wrote: 23 May 2019, 20:12 You don’t pull the front wheel bearing off the hub.
people are getting mixed up, the original question is if he needs a puller to get the hub assembly out of the knuckle. Often they are rusted in place and have to be beaten out (discard) or use a slide hammer. Use a three jaw to push back the axel if rusted In the hub as suggested.
do not keep screwing the puller against the axel to remove the hub as the transmission or axle will be damaged possibly. from large side load not designed to resist.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I don't get mixed up.
Once the 4 bolts holding the bearing are removed, it is just a matter of some hammering, it will come out.
