With the new 80 bar sensor installed it fixed the DEM-0001 but now getting DEM-0007. It's getting no hydraulic pressure reading.vtl wrote: 14 Jun 2019, 06:55 DEM connectors are not soldered to the board, just plugged in mechanically. They don't take any abuse, yours may have lost electrical contact.
Since it's reading temperature correctly you think it could be an internal connection where the sensor transmits the pressure readings? The outer terminal where the sensor slides into appears in good shape. I've cleaned it several times and applied a tab of dielectric grease.
I'll need to test the pump with 12V. I gave it 9V yesterday but got no response.
Also filled it with new Haldex fluid.
