I'll try to use an inverted tapping drill bit.
I'm thinking of drilling a pre-hole and then drilling an invariant tapping drill. It should work. Thanks for your advice.
850 engine air hoses - rear springs - door cylinder & ignition
crlande
- Year and Model: 240DL;850;S70
- Has thanked: 1 time
- Been thanked: 36 times
The anchor is hollow so the splines of the flat bolt head are only held in place by a few millimeters of the anchor. I stuck my drill right thru the spring and was able to drill a hole at an angle into the flat head bolt and put something into the hole to prevent the bolt rotating while I turned the nut. You will be surprised how little is material is holding that bolt in the anchor.
- 18 Replies
- 15066 Views
Last post by LadieRed
- 1315 Views
Last post by Georgeandkira
- 2849 Views
- 2151 Views
Last post by precopster
- 5606 Views
Last post by EanBarnard
