Meanwhile just drive with the dipstick up or remove the O-ring. If you smell burning oil inside the car you know it is venting quite a bit.cfelberg wrote: 09 Nov 2019, 09:37 I'll keep on eye on the dipstick. I checked it a couple of times within the last few days and it may have moved up a millimeter if at all. I'm just not sure what the next step would be - I was hoping there was an item that I overlooked that was causing a blockage. Thanks!
2002 volvo s60 2.4t PCV still blocked after service/replacement
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- MoVolvos
I forgot. After I installed the PCV system on my 98 S70 T5 it still did not work well. It's did stop the oil dipstick gushing however. It been awhile and I have not done another PCV but if my memory serves me right I found a plug vacuum hose going to the PTC. I think that's call the PTC.MoVolvos wrote: 09 Nov 2019, 17:13Meanwhile just drive with the dipstick up or remove the O-ring. If you smell burning oil inside the car you know it is venting quite a bit.cfelberg wrote: 09 Nov 2019, 09:37 I'll keep on eye on the dipstick. I checked it a couple of times within the last few days and it may have moved up a millimeter if at all. I'm just not sure what the next step would be - I was hoping there was an item that I overlooked that was causing a blockage. Thanks!
EDIT: Just read the OP and I cleaned the PTC also and it was a vacuum line going to it that was plugged.
cfelberg
- Year and Model: 2002 s60
- Has thanked: 2 times
- Been thanked: 3 times
Yeah, I was hoping it was due to PTC after reading some posts about it but mine was completely clear, so that's why I was left scratching my head. Car seems to be running well at this point, so I guess I will do what you suggested with the dip stick and continue to monitor it.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
If the glove sucked inward real well at idle but then inflated when under load then it might just be that your engine has more blow-by than than the PCV system is capable of evacuating from the crankcase.
cfelberg
If this is the case then what is the best course of action?chrism wrote: 09 Nov 2019, 18:21 If the glove sucked inward real well at idle but then inflated when under load then it might just be that your engine has more blow-by than than the PCV system is capable of evacuating from the crankcase.
- MoVolvos
Do you mean the vacuum line is clear also?cfelberg wrote: 09 Nov 2019, 18:05 Yeah, I was hoping it was due to PTC after reading some posts about it but mine was completely clear, so that's why I was left scratching my head. Car seems to be running well at this point, so I guess I will do what you suggested with the dip stick and continue to monitor it.
A 5W-40 would do well in the 2002. Try the Rotella T6. An oil change is cheap so worth a try.chrism wrote: 09 Nov 2019, 18:21 If the glove sucked inward real well at idle but then inflated when under load then it might just be that your engine has more blow-by than than the PCV system is capable of evacuating from the crankcase.
cfelberg
MoVolvos wrote: 09 Nov 2019, 18:35Do you mean the vacuum line is clear also?cfelberg wrote: 09 Nov 2019, 18:05 Yeah, I was hoping it was due to PTC after reading some posts about it but mine was completely clear, so that's why I was left scratching my head. Car seems to be running well at this point, so I guess I will do what you suggested with the dip stick and continue to monitor it.
Yes, it is a brand new line.
- MoVolvos
Are there other small or medium vacuum lines related to the PCV? I think it was around 2012 when I did the work. If so, remove and push air through those to double check.cfelberg wrote: 09 Nov 2019, 18:38Yes, it is a brand new line.MoVolvos wrote: 09 Nov 2019, 18:35Do you mean the vacuum line is clear also?cfelberg wrote: 09 Nov 2019, 18:05 Yeah, I was hoping it was due to PTC after reading some posts about it but mine was completely clear, so that's why I was left scratching my head. Car seems to be running well at this point, so I guess I will do what you suggested with the dip stick and continue to monitor it.
cfelberg
MoVolvos wrote: 09 Nov 2019, 18:53There is just one hose that goes directly to the top of the PTC and it is the hose from that long 90 degree hose assembly from the breather box. There are a couple of small vacuum lines that enter the turbo intake tube very near the PTC on their own nipples, but not connected to the PTC directly. Are these the ones you are thinking of?cfelberg wrote: 09 Nov 2019, 18:38Are there other small or medium vacuum lines related to the PCV? I think it was around 2012 when I did the work. If so, remove push air through those to double check.MoVolvos wrote: 09 Nov 2019, 18:35
- MoVolvos
cfelberg wrote: 09 Nov 2019, 19:02Scroll down and see the PTC diagram. It shows a large and small vacuum line. I believe the small one was clogged on mine. It's been awhile.MoVolvos wrote: 09 Nov 2019, 18:53There is just one hose that goes directly to the top of the PTC and it is the hose from that long 90 degree hose assembly from the breather box. There are a couple of small vacuum lines that enter the turbo intake tube very near the PTC on their own nipples, but not connected to the PTC directly. Are these the ones you are thinking of?cfelberg wrote: 09 Nov 2019, 18:38
http://lakesidedp.com/uploadpics/pcv/
- 2806 Views
- 24 Replies
- 9312 Views
- 30 Replies
- 9158 Views
Last post by Ben850
- 1373 Views
Last post by precopster
- 1193 Views
Last post by Nismou20
