Rust protection improvement
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
I'm concerned about large scale rust protection, such as coating the entire underside of a car. A "quick and dirty" body shop once suggested that they could spray large sections of the car with POR 15. I've had mixed results with it, where it has been solid on my rusted heat shield for years but simply rusted around the repair on my 240 floorboards (so not the POR 15's fault?).
Always use the POR rust preparation spray first in addition to any other surface preparation methods they recommend.
FireFox31
Has thanked: 1610 times
Been thanked: 4065 times
https://www.amazon.com/ACF-50-Anti-Corr ... 8131&psc=1
ACF-50 is the stuff I’ve seen on carriers
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
abscate wrote: 03 Dec 2019, 20:28
abscate wrote: 25 Nov 2019, 17:29 I’ve busted knuckles on 7 Volvo’s Now,and they are the best rust protected brand I’ve worked on.
Fluid film is cool, wcm has it on his car
I lied about wcm’s csr, I’ll get him to cough up the product name.
Aero 303 or something like that?
ACF 50 https://www.amazon.com/ACF-50-Anti-Corr ... 561&sr=8-1
Don't apply it to electrical if you can avoid it.
vovo850
Year and Model: 1995 850 glt
Has thanked: 49 times
Post by vovo850 »
I bought corrosionX-hd this year, I used it on my truck and will be applying it to the volvo I hope soon.
It's just like fluidfilm a bit thicker and a lot more pricier. I liked everything I read about it.
I've only used fluidfilm in the can so I can't really compare the viscosity in bulk form but I can't see this stuff
in a can.
1995 Volvo 850 GLT N/A automatic wagon
Rattnalle
Year and Model: 2004 V70 2.5T
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Regardless of brands used you want at least two different products. A thin oil to penetrate well, reach every corner inside the car and stop rust that had already started and then a thicker product to protect from mechanical wear.
vovo850
Post by vovo850 »
Rattnalle wrote: 08 Dec 2019, 10:29 Regardless of brands used you want at least two different products. A thin oil to penetrate well, reach every corner inside the car and stop rust that had already started and then a thicker product to protect from mechanical wear.
corossionX-hd has good creep factor, it will do both. It is used in the aircraft industry and recommended for boat trailers.
With that said, it is my first time using it and I'm curious how it will hold up on my old pickup.
I do plan on using on the volvo here before the month is over. I've just been so busy I haven't had a chance yet.
