That limited use is also part of the problem as not using it allows it to seize through lack of use. Not necessarily just the cable but the mechanism, which in turn strains the cable and breaks the seal and sheath just forward of the rear wheels allowing moisture in.
Parking brake cables Topic is solved
- Has thanked: 2200 times
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Driver's side works perfectly,cable sheath have no cracks.
The main problem with passenger's side is that cable sheath is cracked in two usual spots and it seems that this is where the cable seized.
Expander have zero rust on it.
Driver's side is perfect.
I will report results.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Parking brake functionality restored!
Cable was seized.
Cable was seized.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
A real pain to replace, but good to hear full function restored!
- misha
It wasn't so bad like i was expected it to be.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 949 Views
- 1621 Views
Last post by pdr1966sc
- 17 Replies
- 1955 Views
- 393 Views
Last post by MotorTheresa
- 7060 Views
Last post by oragex
