That would be lovely to say the least.
Gas Smell Volvo 850 GLT
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
I looked at it, I don't see any leaks but maybe its enough so that vapor escapes but I have to pour some fuel in while I look at the top of the fuel pump, nothing is leaking from the tank neck.erikv11 wrote: 07 Feb 2020, 13:52Yes, yes yes yes on the gasket. I've had that fix a gas leak at least twice. They get hard and seal poorly or even crack.mecheng wrote: 07 Feb 2020, 06:49 ... Does the gasket on the fuel pump seal go bad or is it mainly the hose? ...
By far the way to go is to pull the cover on the fuel pump and try to get an eyeball on the leak, I'd keep pushing that. And look up from under the car etc.
I don't think the "wax" coating on the wire entry port actually leads to fuel leakage, but rather it breaks down and crumbles away either with age or when there is a leak causing gas to pool up on top of it.
Rollover valve is right by the fuel filter: viewtopic.php?f=1&t=70426
What about the seal on the fuel sending unit?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Has thanked: 311 times
- Been thanked: 817 times
I've not heard of the sending unit seal leaking, and for me the only time I have ever touched a sending unit is when I harvested the one from a parts car. But makes sense to suspect it.
- 37 Replies
- 3857 Views
- 233 Views
Last post by jmartin919
- 1638 Views
Last post by ir637113
- 297 Views
Last post by fredt2
- 2462 Views
Last post by mountain73
