P80 Radiator oil coolant line connection parts
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
In my experience the transition is clean starting in 99 yes. But I read on this forum somewhere recently that some 98 may have the squeeze locks? Or that was something else ... Just eyeballing them will settle it very simply
aahmes57
Year and Model: 1998 S70 GLT
Post by aahmes57 »
Ok, Got it. so I need two kits, $50. Thanks for straightening me out. Once I put this in then I can start it run it and test it, do the iming belt, struts etc etc. pcv
Thanks again.
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
Post by erikv11 »
bmdubya1198 wrote: 26 Feb 2020, 22:29 ... something or other ...
aahmes57 wrote: 28 Feb 2020, 08:20 Thanks for the info gentlemen and bmdubya1198. ...
:lol: :lol:
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
erikv11 wrote: 28 Feb 2020, 13:18
:lol: :lol:
:lol: I get special recognition above the rest of the gentlemen!
Has thanked: 1611 times
Been thanked: 4072 times
Indeed you were set apart and upon.
Manjuu
Year and Model: 2000 s70
Post by Manjuu »
Hey, does anybody know how to properly install the green retainer clips onto the oil coolant hoses and to the radiator?
bmdubya1198
Manjuu wrote: 19 Mar 2020, 12:46 Hey, does anybody know how to properly install the green retainer clips onto the oil coolant hoses and to the radiator?
You have to slide it onto the end of the hose, then clip it into the radiator. There's a groove in the hose end for the green clip to grab onto.
Manjuu
Post by Manjuu »
So slide it to the end of the hose where the ring stops it? Or snap it on to the tip of the hose?
Manjuu wrote: 20 Mar 2020, 08:32 So slide it to the end of the hose where the ring stops it? Or snap it on to the tip of the hose?
You don't have oil cooler to radiator hoses on a MY 2000 unless the engine has been swapped. That uses the box style cooler on the right side of the engine, rear of car.
For the transmission they should look like this, and they push in until you hear the nice click of the green ears engaging the groove
Screen Shot 2020-03-20 at 11.11.09 AM.png (533.26 KiB) Viewed 914 times
bmdubya1198
Yup, you only have a transmission cooler on your 2000, but that's how they are installed.
