It's even cleaner now per your suggestion I clean the heck out of it after this pic. I would like to stop this leak as it drips through belly pan onto driveway. I already replaced the inner seal the other day, a pain, it was in there pretty good. Tell me more about outer seal...more difficult? Can I grab an outer edge of seal if pre-load adjuster nut is out? Or am I looking at drive a screw throught it and pull?
Thanks again.
Hmm...I was responding to Jimmy's post but it got added to xHearts. Anyway, this is a nice picture of the adjuster nut and those are the exact same parts I ordered! Even got another inner seal even thought I just replaced it (case something goes wrong).
I suspect there are some thread on that small inner lip. I read somewhere thats how you pre-load the bearing just beneath it. But this pic help me understand the anatomy of this area. Thanks!
I use screws or drill two holes and use a seal hook I have had for years. If the adjuster is removed the back side is accessible so seal could be pushed/drive out with a screwdriver.
That part is threaded, the threads are in the photo. Tabs, O ring groove, threads is the order foreground to rear. The O ring is visible when you clean it as there is a small depth of aluminum on outer edge of O ring groove.
I have done full bearing replacements on many of these of this version with diagonal split case. I'm in TX and most were easy but the few I ran across that were cars that spent time in salty areas are the ones I issued the alternate clean and externally seal suggestion. I have one running around that has teflon plumbers sealant on the threads with RTV on outisde. Perfect internals but the area the O ring would seal against was corroded.
My parts arrived this morning and with another heat wave in WNY, I changed the adjuster nut o-ring and outer seal! I heeded your warning and cleaned the snot out of the angle gear area before opening it up. The new adjuster nut tool worked wonders!
I found that the outer seal was actually fine, nothing wrong that I could see. The o-ring was harden but not damaged. I removed the adjuster nut using the tool and it took 9 revolutions to remove it. When I put it back I used a torque wrench to 50 nm ( 36 ft lbs) and it took about 9 1/2 turns. Fresh Mobil 1 syn 75-90, fill til it spills and removed 100ml. Everything buttoned up (except the dust shield for wheel! doh!).
I'm gonna call this resolved for now...frankly I don't want to know if it still leaks I'm so tired of crawling under the car. Thanks for everyone's help!
Thought I'd post an update regarding my bevel gear leak. Been driving for a couple days and I no longer have oil in the driveway. Although I replaced both RF axel seals and the adjuster nut o-ring, I'm convinced it was just the o-ring. However since I was in there I suppose it was a good idea to replace the seals. But frankly they look very good (160K). Also, I highly recommend the special adjuster nut removal tool, because not only was I able to remove the adjuster nut easily but I was also able to use it with a torque wrench on installation. Thanks again for advice on this problem!
Skymongrel,
Thank you for posting this thread.
Is your bevel gear still showing a lack of wetness?
Reading back, I get the impression you re-sealed your BG "adjuster nut" with it still bolted up to the trans, or have I got that wrong?
Either way, I was glad to see you were amongst the dry undercarriage fellows
Being locked down now in MN, I'm going to be tackling some long put-off & not so fun jobs; 284k XC70 BG leak is going to be resolved at long last.
Last time I had it on the hook I was almost certain I had zero'd in the leak's source(s) to the adjuster nut side of the equation. I believe I may have been wrong, but only in part. I do think I have a leak there, but also at the "rear" output flange seal.
Like Jimmy57 said, I'm sure I'll see pitting on mine given the miles & salt exposure.
If you don't mind, I'm going to add some photos to your thread of some seals that may also need to be replaced when doing the adjuster nut o-ring. I'll also try to add seal clickable links.
The above 5 pictures are of the rear/driveshaft/output flange BG seal. They are taken from one of my spare BG’s which has already been re-sealed.
Nice pics. I should have taken some but my iphone battery was shot and couldn't get any good ones.
I think its important to really really clean and scrub with a copper wire brush the Bevel Gear and surrounding area to track down the leaks. I did not want to remove the BG so I went after the little things first. I think the big take away from this experience is that the o-ring behind the adjuster nut can leak! And this isn't the most common google search result when troubleshooting the problem. I was an easy job ONLY because I bought the removal tool ($33).
BTW with a 160k miles I believe both my RH axel seals were actually in great shape and didn't need to be changed.
