This thread helped me out today.
Ive been chasing a no start with Earl, a 1998 V70 NA which has compression, timing, spark, and fuel.
Main relay went bad.
I just checked the resistance on the cam sensor 9146180 and its 300kOhm - open circuit on my cheap meter - per Roberts Video should be about 500-1000 Ohm
It appears P80s use either the BOSCH 9146180 /internal cam position sensor
they can have a DENSO sensor (9202134) which inserts into a boss external in the housing (labelled 9186812) and has the actual sensor
New ones are $300 in Volvo colors, $100 for aftermarket decent brand. (Bosch or Mehle)
P80 p0340 Camshaft Position Sensor 9146108 and 9202134 (1998 MY change)
- Has thanked: 1613 times
- Been thanked: 4078 times
Added more info to title for search
I have two 1998s in the driveway at moment, one with each of these exhaust cam position sensors
There are no VIN breaks in FCP or at Volvowebstore, so order by part number
They are not interchangeable
- Has thanked: 312 times
- Been thanked: 818 times
You have a 98 with a Denso CPS?
Are you sure it's not a 99?
Crap. Maybe I did harvest it from the 2016 99 V70...
I better go check the inventory In my classifieds.....
- 2826 Views
Last post by Luzanov345
- 2982 Views
Last post by RickHaleParker
- 59 Replies
- 2603 Views
Last post by CoupeC70
- 1678 Views
Last post by cn90
- 642 Views
Last post by jackissocool
