96 850T5 Hard restart after engine is hot in hot weather.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Just remove it and blow through it in both directions....if it's closed...it's good.
If you can blow through it,it's bad and stuck open.
It's unpowered state is closed.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
redbeak1
Year and Model: 850t5 1996
Has thanked: 7 times
Been thanked: 2 times
Post by redbeak1 »
misha wrote: 27 May 2020, 10:04 Just remove it and blow through it in both directions....if it's closed...it's good.
I can not blow through in the direction of the arrow, but I can in the opposite direction. What does this tell you?
misha
Post by misha »
Did you disconnected it's connector during this test?
It should be closed in both directions when disconnected.
Arrow is pointing towards intake manifold?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
redbeak1
Post by redbeak1 »
Yes, I removed it from the car. Arrow is pointing toward manifold when installed. I used very light compressed air. I could not get air through it in the direction of the arrow, but I was able to... going in the opposite direction. I would think that this is a one direction valve when activated.
93ForMe
Year and Model: 1993 850
Been thanked: 17 times
Post by 93ForMe »
Hi redbeak1,
I am having similar issues, and I think I may have had a break-though with it today.
My problem seemed very temperature related, but I had switched out the ECT sensor and they persisted. Today I pulled apart the female connector that the ECT plugs into and found that the sheath around the female barrel connectors had started to break down. I cut it away at the base and found a whole lot of corrosion that I cleaned out. Corrosion will increase resistance and make your car think that it is colder than it is. Cold starts, no problem. Hot starts, problem.
Here is my thread, I have a couple of links to pictures of the connector:
viewtopic.php?f=1&t=93975&start=20#p543693
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
93ForMe wrote: 27 May 2020, 18:02 Hi redbeak1,
That's a good point. Corrosion on this connector is very common on 850s, it's definitely worth a careful look.
redbeak1
Post by redbeak1 »
Hi 93Forme, I read your thread a couple of times. Our problems are similar but not exact. My car has to get really hot. A run on the highway pulling a trailer in 80 degree weather and stopping for a 20 minute break would cause a hard start issue. It seems from your thread that once your car is past being warmed up, and is hot, it runs fine.
I once had a intermittent cut off of the engine problem that went on for a long time. I replaced the Fuel Injection relay(the grey one above the radiator). The problem turned out to be the defective new relay. I went nuts checking everything else. I had to wait for the engine to be completely dead before troubleshooting led me back to the same relay that was changed. The Bosch factory didn't do a good job soldering inside the relay. Once the engine was hot and I would hit a bump on the highway the engine died. I cleared the code which came up as a Throttle position sensor that was also replaced. After that the engine ran fine, but would cut out rarely until resolved.
I really hope it turns out to be the wiring in your car. After over 25 years, we can't complain that some plastics start to degrade. Otherwise these cars are tanks. I will also check that same ECT connection tomorrow.
I will keep everyone posted if I can resolve this, especially since we are going into summer!!
redbeak1
Post by redbeak1 »
Hi Misha, would you conclude that if I can blow through it in the opposite direction of the arrow, that the valve is no good? Thank you for all your help.
misha
Post by misha »
Just checked mine.....closed in both directions when engine is not running.
Your's could be failing....since it's closed in just one direction.
Here you can see that a good evap valve is closed in both directions:
https://volvo850wagon.wordpress.com/tag/evap/
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
redbeak1
Post by redbeak1 »
misha wrote: 28 May 2020, 17:16 Just checked mine.....closed in both directions when engine is not running.
Thank you-thank you so much!! You and everyone on this forum has helped so much. I will report back with any new findings.
